network device problem
(Topic created on: 05-05-2018 06:24 PM)
raj7421
my samsung s9 plus shows poor connectivity of network.network show full but show emergency calls only.at the same time my brother is able to call with his mobile using same network sim.i am attaching screen shot also .look into this and rectifye0f01f7d-9528-4f8b-9eee-460b830e2ed9.jpg
5 Comments
Harsha27
Same problem here since the last update
GalaxyTeam
Indian S9/S9+ Telegram Support Group, Join Us (300+ Members)
https://t.me/joinchat/DvvVrkv68Wr7Q3P0BKHnVA5cdfd866-a11a-4df2-914d-eeabaad6a652.jpg
vicky1361
same problem bro after march security patch update
PavanR
First try a network reset and failing that a factory reset. Use smart switch to backup any important stuff. I have the update too and there is no problem here. A factory reset almost always is recommended in case of issues post update.
admin_
Thanks for being a part of Samsung community. We would like to inform you kindly follow the steps below to resolve your concern:-
- Check by using any other SIM card.
- Ensure that network frequency of your device should be selected on Auto-mode.
- Menu > Settings > Connections > Mobile Networks > Network Mode > Select auto mode (GSM/WCDMA/LTE).
- Search for the Network Manually as follows:
Menu > Settings > Connections > Mobile Networks > Network Operators > Select Manual Search.
- Kindly go to settings >> General management >> Reset >> Reset network settings.
Be sure to hit ♡ when you find an answer that works for you. For Further assistance, you can get in touch with us via Live Chat option by following- http://livechat.support.samsung.com/Customer_new/IN. You can also connect us via Samsung Members web community by following mentioned url-https://community.samsungmembers.com/en_IN#/
