network connection failed error and battery drain in s10 plus
(Topic created on: 01-17-2022 09:25 AM)
kapilrohaj
There is a big issue after updating to android 12 . Battery is heavily draining and also network problem , it disconnecting again and again.
 Fixed this issue. and not only s10 plus ,s10 lite, s20 all are facing rapid drain after update it's not regular drain
 #s10plus
8 Comments
h123456789
Next update solve this issue
S21 ultra go the update
kapilrohaj
nice, thanks for sharing
himagupta
Yeah huge issue for battery and network.
AYush2313
True check my latest post for all issue's
karandriems
Network issue i am also facing
sarfarazahmed
reset the network settings
It can help
Yashraghuwanshi
Beginner Level 4
Yes battery drain issue facing after android 12
cs-member13
Expert Level 4
Dear Samsung Member,
We acknowledge your query and apologize for the same. To resolve your device network issue please visit this link: https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-smartphone-how-to-optimise-network-...
To resolve your device battery drain issue please visit this link: https://www.samsung.com/in/support/mobile-devices/how-can-i-optimise-and-extend-the-battery-life-on-...
In case the issue still occurs. Please register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report/Ask questions).
