mobile network problem
(Topic created on: 03-31-2018 11:15 PM)
someone
suddenly stopped network. and showing 'no service'
5 Comments
mohit1212
bhai ye sab k mobile m ho rha h jab se update aaya h or samsung ko koi parvah nahi h j 7 max j7 prime on next in sab m problem aa rhi h
Shripad
samsung sayes restart the phone and run in safe mode and insert the sim properly
Golu998
how to run the device in safe mode ??
admin_
Thanks for being a part of Samsung community. We would like to inform you kindly follow the steps below to resolve your concern:-
- Check by using any other SIM card.
- Ensure that network frequency of your device should be selected on Auto-mode.
- Menu > Settings > Connections > Mobile Networks > Network Mode > Select auto mode (GSM/WCDMA/LTE).
- Search for the Network Manually as follows:
Menu > Settings > Connections > Mobile Networks > Network Operators > Select Manual Search.
- Kindly go to settings >> General management >> Reset >> Reset network settings.
Be sure to hit ♡ when you find an answer that works for you. For Further assistance, you can get in touch with us via Live Chat option by following- http://livechat.support.samsung.com/Customer_new/IN. You can also connect us via Samsung Members web community by following mentioned url-https://community.samsungmembers.com/en_IN#/
Sonje007
from few days are facing a network issue automatically network will be stop I will switch my network jio to idea then also same error comes please help as soon as check error my friends also facing this error on their mobile......
A5 2016
