kittu92
05-05-2017 11:45 PM in
how update through smart switch when i connected to pc it is not showing update button
4 Comments
Not applicable
05-06-2017 08:48 AM in
Because latest updates have already been installed in your phone
kittu92
05-06-2017 10:45 AM in
it shows update on phone. and while connecting to smart switch it is not showing
Jagdesh001
05-06-2017 09:25 PM in
the software patch may compressed to 250 mb from 1 gb file... try to locate ... upload in device..... install the certificates manually
admin_
05-07-2017 03:14 PM in
Thanks for being with Samsung and for sharing your concern. Kindly check given below procedure for updating device through Samsung Smart Switch at Home.
Requirements:-
• High speed internet connection (minimum 2 MBPS)
• Handset’s battery should be fully charged.
• Continuous Power backup (in case of power failure, handset might be crashed)
Step 1
Install the updated version of Samsung Smart Switch in your PC/Laptop. The same can be downloaded from the link given below-
http://www.samsung.com/in/support/smartswitch/
Step 2
After installation of smart switch on PC/Laptop, connect your handset via USB cable with PC/Laptop.
Step 3
Notification will appear in Samsung smart switch window if the updates are available for respective devices.
Points to remember:-
1. Do not disconnect the handset during firmware updation.
2. Please ensure that power supply and internet connection don’t get interrupted.
3. This process might take 30 – 45 minutes approximately depending upon the internet speed.
Requirements:-
Step 1
Step 2
Step 3
