how to uninstall reminder?
(Topic created on: 06-18-2017 10:08 PM)
Tashrif
I accidentally turned on Bixby and accidentally turned on reminder. I need help to disable reminder.
8 Comments
Jakka
Go to Bixby Home page > Tap on Reminder icon > Tap on More (Which is showing 3 dotts on top right corner) > Tap on Settings > Tap on 2nd option > Make it off.
Tashrif
thanks.
Jakka
Hello Friend, by the way, here is one link to explore all Samsung Smart Features. You can watch in your free time. There are 100 Features explained in this.
https://youtu.be/Oad3t8ZDDcY
Tashrif
can you please send me some screenshots please.
Tashrif
I actually could not turn off reminder
Tashrif
actually I want to disable reminder
admin_
Thanks for being with Samsung and sharing your concern. We would like to inform you that kindly follow the given steps mention below for overcome issue:
Navigate to Apps > Reminder > Hit on three dot at right side corner > Delete.
Please give all S8 plus features on S7 edge.... Or u can't give bcoz all will stick to S7 edge and not buy S8 plus... I knw this could be a real reason for not updating S7 edge with S8 features......
