Resolved! Solved
galxy s9 display problems
(Topic created on: 10-07-2020 11:27 PM)
imranstunts
having display issues it has only been a 1 .3 years so thats how flagship phone works.my phone has never been dropped or anything i was using my phone very carefully. Then why did it happend samsung do something about this please😔
Never using another samsung again
This is last
Not applicable
bhai update ke bad hui hena ya problem?
15 Comments
Not applicable
what is display problem that tell first
imranstunts
wait giving the pic
imranstunts
Not applicable
😢 sad ..display gone ... none of the software update can fixed it ... only solution is change the display..... I think basically you simply update software via mobile data or wifi which is not proper process in samsung devices as samsung provides non A/B partition type ota software not like other company hence anything mysterious can be happened with device.... it's recommended and process to install software via smart switch and pc or from odin or through authorised samsung service center as they use odin only for their official purpose... I am using s9 also I never update this and my old note 3 by mobile data or wifi.... as many users s9,note9, note20 destroyed their display forever
Not applicable
benten
I am also suffering from this 😭 😫 issue what was the solution
imranstunts
No solution bro,i am using rhe phone that way.it only happens when the phone is not turned on by always display
benten
But my always on display is turn on. Still I am suffering from this issue
imranstunts
so if that is the case will my warranty will be voided in this situation
