facing problem
(Topic created on: 08-08-2017 08:52 AM)
S7EdgeOne
see this guys the icon allignment is not proper
what to do...???
it's very irritating to see such things in a 50k flagship
15 Comments
Kaash
go to galaxy apps / google store search clock and calender if having update do it
ashishsingh
mine looks good
Prince
Restart Your 50k Flagship😅🤣 or switch off & turn it on in safe mode
GeekGuy
just change the grid. it will be fine.
man, i hate to say this, but I have seen you always complaining about your S7 Edge previously being so laggy and problematic all the time and of course the fact that you have mentioned it thoroughly that's it's flagship and expensive.
the problem you don't see? you have some really shity apps which tend to slow down your phone and are risky as well for sharing your private datas with others.
Don't take me wrong and I mean no offence but before you always complain, see that you might as well be wrong.
I am using the same phone and I am bad ass user then when it comes to usability and to make out the best of the phone, it heats for sure, but NEVER LAGS.
All the best👍
S7EdgeOne
is there a bug in 5x5
GeekGuy
I guess it's a bug. With those fonts.
S7EdgeOne
the same thing again happens....even thought I change the grid and font
and after update the lagging issue has been solved
GeekGuy
uninstall the s8 calender and clock app you have
reboot the phone, hope it works.
S7EdgeOne
but it's the update from galaxy app to clock and calender
it can't be uninstalled
