11-14-2020 12:20 AM in
Galaxy S- Mark as New
11-14-2020 01:02 AM in
Galaxy S1. Connection>more connections settings> disable nearby device settings.
2. Location>improve accuracy >disable
A. Wifi scanning
B. Bluetooth scanning .
And enable these 2 options.
A. Adaptive battery
B. Put Unused Apps to Sleep.
4. Long press on each app specially 3rd party app(LIKE FACEBOOK, YOUTUBE) and rarely used apps and also ON "GOOGLE APP" as well, then click on>app info> go to these 3 options below on by one
6. Go to settings > Google > on device sharing> check which 3rd party apps present there for e.g. if you use paytm , paytm will shared data to show recommendation and suggestion which also cause battery drain
7. Go to settings > account and backup> account > check which app syncing automatically there, and if any app which not necessary to auto sync then click on it and "disable sync"
8. Go to settings >apps>search "weather" >click on settings icon right side > change "auto refresh" settings as per your requirements and disable some unnecessary reminder. ( due to auto refresh it continuously consuming battery)
10. Google >click on 3dot at right top corner>usage and diagnostics >off this option.
11-14-2020 04:13 AM in
11-14-2020 10:35 AM in
11-14-2020 10:55 AM in
11-20-2020 06:23 PM in
Galaxy SDear Samsung Member,
Please be assured and perform following step to resolve the Camera issue:
>>Please clear data or cache of Camera Application(Tap Settings>Apps>Camera>Storage>Clear Cache/data)
And to resolve "battery drainage" issue please click on the link below:
http://www.samsung.com/in/support/skp/faq/1101689
If the issue still persist, kindly register your concern in Samsung Members app (Samsung Members app > Get help > Feedback > Error report).
Note: Please send device log files within 15 minutes of issue occurrence along with the exact issue details.
