battery drain on s8 oreo
(Topic created on: 03-07-2018 06:14 PM)
siddass
battery is draining very fast.. does not even stay for half a day.
My phone is not even 48 years old.
bought it on 5th March 2018 evening
7 Comments
admin_
Thank you for Joining Samsung community. We would recommend you to follow some troubleshooting steps in order to further isolate what you may be experiencing in your device. Find the troubleshooting steps on the provided link http://www.samsung.com/in/support/skp/faq/1101689. Please let us know what steps you have taken and if you have noticed any changes or improvements as this will help the Community to provide you further troubleshooting steps without repeating any procedure which you may have already followed. Be sure to hit ♡ when you find an answer that works for you.
For Further assistance, you can get in touch with us via Live Chat option by following- http://livechat.support.samsung.com/Customer_new/IN. You can also connect us via Samsung Members web community by following mentioned url-https://community.samsungmembers.com/en_IN#/
siddass
have tried doing all that..
bazzaza
I've been using the phone since 6 months, give it some time to get used to your usage. the phone phone gets optimised after 2 weeks. this happens even after doing a factory reset
siddass
thanks.. let's hope...it works out that way
MiraclePanda
don't worry bro it will work out . just make sure that you are using the phone in right settings.
sahilRana
hmmmmmmm
kshitij33
u can also stop apps that works in background even if u are not using it specially shareit i works in background all the time. so try to block these apps.u can do it from settings/apps/battery then turm off the the permission then it will not work in background.
