battery backup problem in s6
(Topic created on: 10-19-2018 04:21 PM)
adesh2
How can i increase my s6 battery backup
7 Comments
manusharma1
use battery saver
Not applicable
use phone less
PRAM0D
battery saver is a good option.
Nishitkohli
Expert Level 4
use battery saver or go to service centre maybe your battery needs to be replace✌
ZombieHRN
don't use battery saver apps
and if u do have battery saver inbuilt ... they decrease the cpu clock speed and slow down your device.
and its s6 ... u can't expect more!
Awesom0123
Clean your device regularly
Krishna0792
use your phone in power saver mode
use dark wallpaper to exented battery life more by 4 to 5%
turn off wifi ,data connection and location when not using then it will also enhance your battery life
change screen setting to adapted
try these thing
your battery life will be extended two to three hours more
plus put app to sleep which are not used by you of uninstall them
clear app cache using inbuilt cleanear
sure these thing will help you
