android 10 edge light function
(Topic created on: 10-26-2019 05:00 PM)
eden10
There is no more an option for edge light to work only when screen is off. Like there was in android 9.
11 Comments
Nazid
Expert Level 4
yes, its awsm
Not applicable
dy111
not good that was unique feature that keep Samsung phones different frm other devices
Not applicable
what
Not applicable
so what's the problem in that
eden10
the problem is that when the edge lighting is on you cannot reply to the notification without opening the app.
Not applicable
ok
jay77277
it's same available in android 9.0..not a new
eden10
in android 9 you could set it to work only when the screen was off. when the screen is on the notification would come loke normal so you could reply to them without opening the app
