Workaround/Fix : Voicemail notification is persistent and not dissapearing
(Topic created on: 03-05-2023 11:51 AM)
ylnhari
Hi, I recently purchased s23 ultra ( from india) and using local Carrier network (Airtel).From the first day, right after inserting my physical sim card, I am having a persistent notification that do not go away whatever i do.Even the notification settings for App - "phone services" is disabled.Attaching the screenshots for the same.
Possible Fixes I tried
  • Activating voice mail for my carrier network and Setting up voice mail on my phone, and hearing the voice mails.
  • Clearing call settings data and cache.
  • Clearing App - "Phone" data and cache
  • Clearing App - "Phone Services" data and cache.
  • Factory data reset of phone.
  • Trying to silent the notification.
Nothing worked !!!
In my case I noticed that I get this issue only when I use my Airtel sim(indian carrier network) but with other carrier networks, and with other Airtel sims iam not facing this issue.
Fix / Workaround I used:
Converted my physical Sim to E-Sim and that issue is now gone, now i do not have any persistent notification lying in the notification bar.
4 Comments
NOOB_1ST_ACC
Clear data of 'phone' app then go to settings》general management》reset》tap and do reset all settings (It will not delete any personal data).
If found useful/on point then tap on 3 dots and accept as solution.
ylnhari
Not working
ylnhari
Solution/fix/workaround : convert your physical sim to Esim (iam using airtel network services from India and I converted my physical sim to e sim and now that notification has gone)
ylnhari
Remember , this error only happens with my airtel Sim but when I use other's Airtel Sim I do not see that notification
