Resolved! Solved
Wireless power sharing
(Topic created on: 02-01-2024 01:21 PM)
MOQBALI
Samsung Community
 Are any of you having trouble sharing wireless charging?S24 Ultra
Samsung_specialist
The issue is due to the cover of the phone.
6 Comments
brother i am using s 23 ultra 😊
Zammi
Tested reverse charging of S24 with my buds. Works fine.
spheta
Beginner Level 3
I'm having issues. I'm using an s22 Ultra and recently discovered wireless power sharing isn't functioning properly on the device anymore. I can't be sure but it may something to do with the One UI 6 update.
Thank you for responding to me. In fact, I discovered that the problem is with the phone cover, even though it is an original Samsung cover. When purchasing, I asked the employee and he told me that it is good and does not affect wireless charging. After testing, it became clear that it charges wirelessly, but when sharing wireless charging, it does not respond. There is no comment .1706948347471_1706948347465_0.jpg1706948361897_1706948361893_0.jpg
spheta
Beginner Level 3
Mine charges normal as well even with the case. No issues with the Samsung wireless charger (EP-P2400TBEGCA), fast wireless charges at 12-15w. Its just when I try to reverse charge a device I get no indication anything is present or charging when power share is enabled.
Samsung_specialist
