Widgets Drain battery!!!!😴
(Topic created on: a month ago)
Kendrick_Katongo
If you use animated widgets or anything that uses location expect significant battery drains. On your home screen especially. Use still or none animated widgets otherwise don't come here asking for battery tips. I just gave you one big one. One ui 7 comes with so many great features at the cost of battery. The phones that will handle it better are the ones coming with the nee battery tech set for s26 series like the vivo x200 pro.
3 Comments
KSibiya
Thanks I've noticed my b3 doesn't last as long anymore
You're welcome, it's fact many want to overlook but expect a good battery life πŸ”₯.
nadia-k
Savage bro
