Kendrick_Katong o
05-03-2025 01:47 PM (Last edited 05-03-2025 01:48 PM ) in
One UI7, is an amazing update with so many feature packed tweaks.
I have noticed that it's selling point, smooth animations, it's also it's most battery drainer. Anyone who says goodlock modules don't drain battery can wait up until they have one UI 7. I have confirmed as an s24 user. The animations whether smooth or fast have a significant battery drain and you'll notice the stanbytime, battery will lose about 10% or more without being used. I'm not here to discourage anyone but share my findings. As long as you use goodlock modules, light screen wallpapers, animations, and widgets, your battery can never be better.
I can assure try using your phone on one UI 7 with the following settings and judge for yourself.
1) use dark or black wallpers
2) turn off animations all together (no need for battery saver mode)
3) delete good lock modules
4) turn off blur effect
5) choose light profile under device performance
6) turn off vibrations
7) make sure only useful apps use location
😎 Turn off precise location and switch to approximate location, some sensors will be turned off. You'll be glad. You did .
😎 Turn of adaptive brightness (the sensor works anytime you turn on your screen)
9) Turn off adaptive refresh rate
Then come and share your😁
2 Comments
Munatsi399
05-03-2025 07:57 PM in
Yeah usually the 7.1 brings stability....
In years of past, old devices used to get the .0 version then the newest flagship/devices would launch with the .1, then older devices would get the .1 as an update which would improve stability, this time it appears as it took a different approach
Munatsi399
05-03-2025 07:59 PM in
The option presented there are not desirable😅
