Resolved! Solved
WiFi Power Saving mode?
(Topic created on: 09-29-2024 09:00 PM)
Amalms
What is this feature? Does it reduce the connectivity speed?
2 Solutions
Basically, Power Saving Mode analyses patterns in Wi-Fi traffic, and adjusts the wireless connection accordingly. For example, if your email app retrieves e-mail every 15 minutes, the Power Saving Mode recognises this. it then knows that the connections is only needed at this particular interval
Bob86
No it doesn't. I do not experience any reduction in connectivity speed
8 Comments
Amalms
Bob86
Amalms
akrammi
Also, it remembers location as well. So whenever you revisit the same place it will remember the wifi name and setting yoh used. And where you turned off your wifi. It will remember this as well.
Especially when travelling wjen you put your fone airplane mode then it remember last settings whether you switched off you wifi or kept it on when airplane mode was turned on.
Amalms
Samsung_specialist
Wi-Fi Power Saving Mode is a feature designed to conserve battery life on your Samsung mobile device. It works by analyzing your Wi-Fi usage patterns and temporarily disconnecting your device from Wi-Fi networks when it's not actively needed. This can be especially helpful when you're not using your phone for extended periods or when you're in areas with weak Wi-Fi signals, the device might take a slight delay to reconnect to the Wi-Fi network after it has been temporarily disconnected. However, in most cases, the speed difference is minimal and shouldn't be noticeable during regular use.
Amalms
