What is the max Wifi/ Internet speed Cap for S8plus
(Topic created on: 12-14-2017 03:51 PM)
androidguru
I would like to know the maximum speed for receiving internet either through wifi or through service provider on S8 Plus.
For an example if I have 2 Gegabytes internet connection for my wifi then would my Galaxy S8 Plus would provide the same speed on my mobile or like other devices it is only limited to operate at 50Mbps speed.
5 Comments
prakharg
interms of speed through wifi s8 is the fastest phone of 2017 , you can check that
RV27
The WiFi modem in S8 plus is 802.11ac which is theoretically 7Gbps capable but in real conditions around 2Gbps is acheivable
RV27
The LTE modem is capable of 1 Gbps downlink and 150Mbps uplink
androidguru
Thank you all for the feedback
admin_
Thank you for being with Samsung and sharing your concern. We would like to inform you that S8 plus is compatible with Wi-Fi standard 802.11ac and it works on 2.4G+5GHz frequency. Be sure to hit ♡ when you find an answer that works for you.
