Visible gap on volume button side in s20fe5g, also device is heating
(Topic created on: 10-08-2021 09:59 PM)
humble-fool
Edit: guys I have placed replacement order on Amazon, thanks to everyone for helping me out.
Hi guys, recently I have bought se20fe 5g from Amazon. Everything is working great but I have observed few things
1) there is a visible gap on volume button side, can anybody confirm it's common among all s20fe devices or should I place return request, as return window is near requesting to reply asap, for reference I'm adding some pics
2) Though on spec sheet barometer sensor is mentioned, no app is able to detect barometer sensor in my phone.
3) device is getting quite hot even with normal usage, even after updating & downloading all the updates heating is not gone and I can see temp rising till 44-46°c on cpuz application.
It would be great if other fellow users can share their opinions, thanks in advance.
20 Comments
better u go through return the device to amazon
DGarg1989
Same with me with Note 10+..
Already visited service center 3 times....
Still...same result
Bliss-entity
Return it and purchase A52s 5g
this deal is good
onlyashu19
Which deal is good ?
onlyashu19
What are cons of A52s 5g ? Does it has heating issues ? , battery drainage issue or any other ?
Bliss-entity
You can ask some people who have purchased it in samsung members by posting a community post. 🙂
There are some issues like display issues that are being faced by A52s owners.
Better you ask A52s owners via community post
Vinusingh25
Replace it bro
Replace it
