Resolved! Solved
Using phone at 120hz refresh rate consume more battery than 60hz
(Topic created on: 11-03-2024 05:22 PM)
aliMeraz
Vikasofficial
Expert Level 3
Yes 120 hz more consume battery than 60 hz.
But 120 hz is adaptive refresh rate going to 1 to 120hz. During your usage. If you agree my suggestion then click 3 dot button and accept my solution bro❤👏
6 Comments
Vikasofficial
Expert Level 3
Mayank_srma
depend on your uses...but can change some setting this will better then before....If you like please accept as a solution it's help to others users also, click on 3dots in my reply section and click on accept solution. Thanks.
aliMeraz
Which setting
Mayank_srma
Like turn of diagnostic report, background wifi scanning, performance change to lite setting, make routine for location, If you like please accept as a solution it's help to others users also, click on 3dots in my reply section and click on accept solution. Thanks.
goodthings
Yes offcourse you are absolutely right now. If you like please accept as a solution it's help to others users also, click on 3dots in my reply section and click on accept solution. Thanks.
goodthings
Your's most welcome to here.
