USB, OTG Connection Problem
(Topic created on: 08-20-2022 09:38 PM)
Arjun_Limbu
On my galaxy s21 ultra usb on pc or otg is not (connected) reconized, when i connect to pc it shows charging only...i'v done many things or settings possible but still not connected or reconized......how to fix it plz help
2 Comments
If you have tried with different cables and still the issue persists, Visit nearby service center cus maybe the Charging Board is faulty. (I hope you tried with different cables and well as different PC)
cs_member8
Dear Samsung member,
We acknowledge your query and apologize for the inconvenience caused to you and will surely assist you regarding the same and please follow the easy troubleshooting steps which might help to solve the issue.
1. Check different OTG with your device.
2. Check by using another pen drive.
3. Check the USB connection.
Perform interactive checks through the Samsung Members apps.
Path: Samsung members > Get Help > Interactive checks > Charger/USB).
4. Check by using genuine OTG cable.
5. Check whether the device is OTG compatible or not.
6. To clear the data of the USB, please follow the below steps.
Setting > Apps > Three dots (Appearing at top right corner) > Show system apps > Search USB Settings > Tap on storage > clear data of USB Settings.
7: Reset app preferences:
Please follow the below steps.
Settings > Apps > Three dots ( Appearing at the top right corner) > Reset app preferences (It'll reset the permissions of all applications)
In case the issue still occurs. Please register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report).
Thank you for writing to us.
Samsung Customer Support.
