Trouble with Sound
(Topic created on: 07-24-2021 12:15 PM)
the_underachiever
Could anyone help me solve the persistent issues I keep having with my S9+. I keep losing sound and microphone functionality and have to constantly reboot my phone in safe mode or factory reset when that doesn't work.
5 Comments
Tsogo_sam05
Hi, please test the receiver and the mic.
1. From the phone dialler, enter *#0283#.
2. Select RCV Packet Loopback ON (it may appear as Start: RCV_1stMic on some devices).
Say a few words as if you were on a call. If you hear your own voice, it's working correctly.
Can you hear your voice?
I think it's more of a software issue than a hardware one. The phone just stops recognizing the audio output devices even though they're working fine. And it happens persistently, it's very frustrating. I'm considering switching phones at this point.
Tsogo_sam05
Apologies for the inconvenience caused.
Kindly note that your device may need to booked in for a Software reload. It seems like the current software loaded on your device is malfunctioning. Please go to the below link to locate the closest Authorized Service Center to you.
https://www.samsung.com/za/support/service-centre/
You can also backup using Smart switch and then factory reset your device. Herewith Smart switch link:
https://www.samsung.com/za/support/smart-switch/
I'm actually based in Zambia, not South Africa so that site won't really be efficient and I've also already tried factory resetting, it didn't work.
Tsogo_sam05
Good morning, the_underachiever apologies for the inconvenience caused, please contact the service providers below.
1. ADEWALE GRILLO T/A CHASE GALLOWAY LIMITED
PLOT 503 GREAT NORTH RD
Zambia, Lusaka
02609674607
2. HAZIDA LIMITED
UNIT 16, ARCADES SHOPPING CENTRE
Zambia, Lusaka
+260)2112 28666
