There is a gap between the back cover and body of my device.
(Topic created on: 11-04-2022 06:36 PM)
rewritingpraveen
A gap has formed between the back cover and body of my device and it is getting wider day by day. Initially I thought it was due to falling, later when I realized it is getting wider I thought of writing here. One of my friend said your battery has swelled and that's pushing the cover outward.
As far as I know battery is placed downwards, my device is opening from top. Battery backup is okay, thus, according to me it's not the battery.
Also, some sticky material is often seen coming out at the opening.
Help! Do I need to check out at service center, if yes, is this covered under Care+ extended warranty?
19 Comments
Guddu-S20FE5G
What? Want to see the gap?
TechyKamal
Yes. By the way, which phone?
S20, wait I'll take a photo and post in a few minutes.
Sid_Karna
How old is your s20fe? If it's more than one year old, check your phone's backpanel carefully. S20fe is one of the most affected models.
sangram21
Immediately go samsung service center. And check that device.
Kunal2
Many users are facing this issue. If you search in community just by typing "back panel" you will knew it
Visit samsung service centre and its cover under warranty. They will stick it for free
Thanks buddy.
Sid_Karna
S20 and A52 series have this issue. You don't have to necessarily post a photo. We all know that the issue is genuine. Go to a service centre and paste the panel back. It's the only option. Hundreds of users are facing this issue due to poor manufacturing quality. I faced it myself.
https://r2.community.samsung.com/t5/Galaxy-Gallery/A52s5g-Back-panel-issue-Photos-for-those-who-aske...
