vvnsk
02-07-2023 10:39 AM in
Ho everyone,
Recently jio has started 5g in my location . The signal at my location is feeble. So mostly my network changes from 4g to 5g and back . So is there any option to change the network mode with just one click. Instead of going inside the
settings-> connections-> mobile networks-> network mode.
I want this setting directly onto the home screen . Is there any shortcut for the same ??
Solved! Go to Solution.
12 Comments
- « Previous
- 1
- 2
- Next »
vvnsk
02-07-2023 11:48 AM in
I tried by searching only
SDC-X
02-07-2023 03:36 PM in
You need to turn on creation of shortcuts in registar, then search inside settings for it to work. The created shortcut will then take you to the network mode page within settings.
vvnsk
02-07-2023 07:43 PM in
After enabling it
It worked for me
Thank you
It worked for me
Thank you
- « Previous
- 1
- 2
- Next »
