Super Fast Charging Speed drastically reduced in S20FE 5G after OneUI 4.1 update
(Topic created on: 04-15-2022 08:52 PM)
mnatraj2000
SOLUTION(edited):-
Hi all, the issue got resolved, it charges slow because the ambient temperature in my area is above 38°C. Recently I travelled in an AC train there the ambient temp is between 27° to 34°C there my phone charged much faster. So to charge faster make sure your environment and ambient temp are cooler.
My Samsung S20 FE 5G takes 1 hr 15mins to charge 30 - 100% with a 25W charger. The charging speed is reduced drastically which is now similar to the 15W charger after OneUI 4.1 update. I think Samsung needs to fix this issue ASAP.
*Enabled fast charging in settings page.
Battery Settings
22 Comments
Danny7
Yes bro..thts y i switch off the phone and charge it
mnatraj2000
But the speed is even less
venkyk966
Yes
Prv002
Does your phone heat up in normal usage plz tell me bro mine heat up drastically...
mnatraj2000
Yeah heats a lot even while scrolling through Instagram
Prv002
After update???
mnatraj2000
Before also sometimes
Prv002
Charging speed also decrease???
mnatraj2000
Charging speed is decreased after the update. Sometimes 15W is charging faster than 25W
