08-09-2023 05:28 PM in
Galaxy S- Mark as New
08-09-2023 05:48 PM in
08-09-2023 06:02 PM in
08-09-2023 06:08 PM (Last edited 08-09-2023 06:08 PM ) in
Galaxy SThat 7 to 8 hours SOT is only possible if anyone watches Netflix/YouTube continuously on WiFi.
If you're on a 5G network, then switch back to 4G, and it'll give you some extra battery backup.
(If possible, get back to iPhone. Even the Googles own Pixel has issues.)
08-09-2023 08:16 PM in
Galaxy SAnd I just might switch back to iPhone because how poor Samsung has been. It's been less than a month and I'm considering this.
08-09-2023 09:03 PM in
Galaxy SAs for your used case, try a reset and wait at least for a week before the s/w understands your usage patterns. With thr vanilla S23 5-6 hrs of SOT is standard with generic browsing etc. Watching videos will increase the SOT by another 2-3 hrs. Also many users have reported mixed battery issues with June & July updates. I'd suggest hold on for a month or so after a reset and then report back. The last option is you might have got a lemon handset.
08-12-2023 03:55 PM in
Galaxy SDear Samsung Member,
We acknowledge your query. We request you kindly visit the service center for a physical inspection of your device. So that they can check the exact issue with the device and fix it as the earliest. You can locate your nearest service center with this given link: https://www.samsung.com/in/support/service-center/
