Storage issue
(Topic created on: 07-25-2017 01:01 AM)
SammyRocks
Apparently, it appears that all the storage space of my phone is not at all accounted for.
My S6 Edge has storage of 64 GB, assuming that only around 55 GB of storage is available to the user(as the remaining is used by the system for stuff like indexing and others), after calculating all my data, it is only accounted for 40GB. This includes all the hidden system files as well as the thumbnails apart from every folder on the disk available to the user. Now where is the remaining 15 GB? #Shocker!!!!!!
I have installed external disk management apps like MemoryMap, ESFileExplorer and also checked SmartManager as well. There is no clue.
Any ideas people?
8 Comments
Ysh
Bhai 64 gb mai pura nhi milata approx 61.5 gb he milta hai us mai se kuch storage internal softwares k liy hota hai.
SammyRocks
nahi bhai... sirf 55 gb hi milta hai user ko...61.5 nahi
Ysh
bro mere s8+ me to 60.89gb mila hai
in my s8+ after factory reset I checked it was around 52gb and after updating inbuilt apps it's got reduced to 49.6gb remaining out of 64gb.
SammyRocks
Samsung India @admin Do you have an answer for this?
admin_
Thank you for your query. The relevant department may serve you better/speedily, if you can provide logs/video by registering this feedback in Error Section (Samsung Members App -> Feedback -> Questions/Errors -> Create -> Error reports).
bhushhhhhh
my phone not show OTG connection
bhushhhhhh
Samsung A9
android 8.0
