Speaker sound downgrade
(Topic created on: 06-10-2023 05:57 PM)
Ribhu20
After one UI 5.1 update s20fe speaker sound downgrade volume label downgrade by Samsung
cs-member11
Dear Samsung Customer,
1. Disconnect anything plugged into the headphone jack like, selfie stick, headphone, Bluetooth, etc.
2. Remove any third-party case, protective films, or any other accessory that usually comes in contact with your device. (If any)
Check device volume settings
Please follow the below steps:
Step1: Navigate to apps screen and tap on Settings.
Step2: Tap on Sound & vibration.
Step3: Tap on Volume.
Step4: Drag the volume adjustment bar left or right to increase or decrease the device volume.
To verify, play music and check the music sound. If the sound quality is good, then your speaker is working fine.
Clear Sound picker data
Step1: Got to Settings
Step2: Apps
Step3: Filter and sort
Step4: Enable "Show system apps"
Step5: Tap "OK"
Step6: Search Sound Picker
Step7: Tap on storage
Step8: clear data of Sound picker.
In case the issue still occurs. Please register your concern in Samsung Members Application (Open Samsung Members Application > Support> Tap on error report > Type your query > Send).
Thank you for writing to us.
Samsung Customer Support.
