smvlogs
β11-19-2024 05:34 PM (Last edited β11-19-2024 05:34 PM ) in
Hi,
Recently my s23fe is got moisture notifications while using type c charger frequently....
I was confused & panic,
But when I try to use original charger insted of third party charger it was normal....
[ SOLUTIONS] :
1. Use only authorised products,
2. Perfect suitable gadgets only,
3. Pouches & screen guard & chargers must be high quality,
4. If your screen guard getting old & if it was broken then change it to perfect model glass,
5. Update your phone regularly & restart your phone weakly once,
( IMPORTANT) : IF ANYTHING WRONG AFTER ALL , THEN MUST VISIT TO OFFICIAL SAMSUNG SERVICE CENTRE !
That's all I can doπ
4 Comments
Toobausama
β11-19-2024 05:37 PM (Last edited β11-19-2024 05:37 PM ) in
Suddenly my earpods couldn't connect. So then i un paired it and then when I checked to pair I can't even find the device
smvlogs
β11-19-2024 05:43 PM in
1. First restart your mobile,
2. Clean your earpods properly,
3. Charge your earpods with powerbank insted of direct charger brick,
[ IMPORTANT ] :
If not working all this process , then visit official samsung software center for help,
It's really usefull.
[ IMPORTANT ] :
Aryankumar_28
β11-19-2024 06:27 PM in
Once check any other device may be connected or battery may dead Once check
smvlogs
β11-19-2024 07:36 PM in
Yes π
