Smartswitch | S24 FE Downgrade | Backup Problem
(Topic created on: 3 weeks ago)
SahPriyanshu
Any idea how to fix this, bcz i won't get a stable update and I stuck on Beta 1 update after the deregister of Beta Update, any way to fix SAMSUNG
OR
Just give a Stable Update to deregister user who stuck on BETA UPDATE
The phone is lagging
OR
Any option to save Backup directly on Google cloud or any other platform
18 Comments
OMKALEESH
Transfer it to SD card
SahPriyanshu
Bro, 200 GB of data in sd card 😮
OMKALEESH
Or maybe in usb
OMKALEESH
Or usb drive
SahPriyanshu
Who will invest such costly storage devices like ₹4000 or plus
OMKALEESH
Then try to uninstall the smartwatch app
SahPriyanshu
What will happen then ?
OMKALEESH
It will clear the data and reset to default settings
SahPriyanshu
This won't work
