PS2527
11-01-2024 09:35 AM in
I recently upgraded from S21 FE to S23 and noticed that the Smart Select option in the edge panel in S23 is unavailable.
Is there a way to enable this
Solved! Go to Solution.
MukhtarK
11-01-2024 09:51 AM in
yes older versions have different tool now you can use this for smart selection
2 Comments
MukhtarK
PS2527
11-01-2024 12:45 PM in
Thank you. This option is impressive
