Secure folder problem
(Topic created on: 10-23-2025 02:23 PM)
Rajashrkar
Hi samsung team
I facing secure folder problem
Whe I am back from secure folder not close .when I am screen off it's close.
2. Problem is my images share secure folder what's app not possible
This update not good ,please same as old one
Update. Secure folder is a private is my privacy
8 Comments
ashhhhhu1
I'm also facing the same problem... i can't sent share photos to secure folder apps like insta, WhatsApp,Facebook
YOUR_EX
1.Bro the feature of secure folder "Each time I leave an app" was removed in ONE UI 8.
2. If u want to share files on secure folder to WhatsApp, first u need move out the files from secure folder.
If you find this helpful, I'd appreciate it if you could accept it as a SOLUTION by clicking 3 vertical dots on my reply. Thank you 😊
Rajashrkar
Too long pross
YOUR_EX
U mean?
Rajashrkar
I mean old secure folder is direct send. but new one is first move the file and send
YOUR_EX
No bro, there's no direct share option. Cause I'm using one ui 7😊
Rajashrkar
I am use previous
YOUR_EX
Yes bro
