Screen recorder not recording audio
(Topic created on: 01-06-2022 08:25 PM)
Karums
Hello there people. My screen recording app from the official galaxy suddenly is not recording the audio. I however tried to restart the phone but it still does not records the audio when i try to record some youtube videos.
Any help regarding this is highly appreciated.
I am using S20 Fe 5g , android 11 with one ui 3.
19 Comments
Muqeeth52
Check the screen recording settings
Select record audio
Karums
Yes i have enabled the media to be on under the screen recorder setting sti i get the issue
Muqeeth52
Then check permission to record the audio
Karums
Where do I find that settings @Muqeeth52
Muqeeth52
Just search permission manager
Select microphone
Then Select samsung capture
Karums
i just checked and it has mic access and also samsung capture has all the permissions turned on
Muqeeth52
Then in this app samsung members
Do diagnostics of microphone
If that doesn't work
Then u can try to hold lower volume key and power button until u see samsung screen
Karums
How do I do diagnostic of mic for this app? Could you please mention where to find it
Muqeeth52
