Screen Lag problem
(Topic created on: 10-05-2022 07:56 PM)
Anindya75
I am using Samsung S20plus.Somtimes screen lights are flashing itslef.Its laging pls fix it to mext update.
Its started from Yesterday
3 Comments
Roshan5
Expert Level 3
Samsung want to sell you S21 Plus or S22 Plus.
Downgrade starts of S20 Plus
Anindya75
Ya bro...
cs_member8
Dear Samsung member,
We acknowledge your query and apologize for the inconvenience caused to you and will surely assist you regarding the same and please follow the easy troubleshooting steps which might help to solve the issue.
Check space availability:
Is there sufficient space available on your device?
Kindly check the space on your device:
Path: Settings > Device Care >Storage
To improve the device performance there should be sufficient space. Request you to keep at least a ''minimum 20% internal memory free''.
Kindly check RAM in your device:-
Path: Settings>Device care>Memory.
To improve the performance RAM of the device should be free. So, clear the RAM memory once a day.
Check app cache
Does the device hang while accessing any particular Application/Game etc?
Please follow the below steps
1- Clear app cache through Device care:
Step1: Navigate to the app's screen and tap on Settings.
Step2: Tap on Device care.
Step3: Tap on Storage.
Step4: Tap on CLEAN NOW.
In case the issue still occurs. Please register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report).
Warm regard,
