Samsung vs iPhone battery
(Topic created on: 01-24-2021 02:12 PM)
Not applicable
Is it true that Samsung phone batteries last longer than iPhone batteries and that we have to change iPhone battery often?
7 Comments
Not applicable
👍 yes Samsung battery last for long bro if it's don't have fault from factory manufacturers ... but you have to remember also some basic criteria to make battery healthy.... like don't charge multiple times a day don't leave device with charging for a week, don't charge battery within extreme heat or cold weather conditions etc
Ronak2012
yes samsung batteries are always better but another i dunno 😕. btw mark this comment as a solution if you get this
Kenzen
Yes its true samsung battery lasts longer becz it has greater battery capacity and also newer android versions like android 10 and 11 has the ability to consume less charge than those compared to iphone ioses.
bhola69
yes
Not applicable
Shivanshu2007
arun forgot to describe subscribing in this video
nripen00
obviously samsung battery is far better than iPhone
