jwalker
03-04-2024 01:49 AM (Last edited 03-04-2024 11:21 AM ) in
After Feb update , My s23 is draining so fast and heating up even if Instagram, YouTube or whatsapp is used.
Device is not supposed to heat up with Instagram or WhatsApp.
Listening to YouTube music ends up in heating upto 39° C. And even if we keep the phone in AC same effect, that is worst as can't blame outside temperature.
Also i am using wifi. Bluetooth and location are turned off. Phone is optimised used device care and all other apps are closed
Is there any solution or update planning to rollout ?
Please don't reply with typical answers Iike reset device, turn off wifi, blutooth. It's a serious software issue and Samsung needs to address this as soon as possible.
Giving this kind of crappy update is so irritating for the users.
25 Comments
- « Previous
- Next »
jwalker
03-04-2024 09:10 PM in
Done i have reported the error
vishal271999
03-05-2024 02:18 PM in
Reset your phone ..it will be fixed
madhuthummala
03-06-2024 10:32 AM in
Iam also facing internet issues
ameen7
03-12-2024 10:21 AM in
Iam also facing same issues
JithinAjith
04-12-2024 12:06 AM in
Settings 》Google 》Devices 》Turn off scan for nearby devices
Settings 》Connections 》More connection settings 》Printing 》Turn off default printing service
Device care 》Battery 》Background usage limit 》Deep sleeping apps 》 add apps
Settings 》Location 》Improve Accuracy 》Turn off Bluetooth and WiFi scanning
Mayank2252
3 weeks ago in
Feeling the same issue. Phone is getting heated after normal use.
- « Previous
- Next »
