Samsung galaxy s23 overheating and battery drain after Feb 2024 update
(Topic created on: 03-04-2024 01:49 AM)
jwalker
After Feb update , My s23 is draining so fast and heating up even if Instagram, YouTube or whatsapp is used.
Device is not supposed to heat up with Instagram or WhatsApp.
Listening to YouTube music ends up in heating upto 39° C. And even if we keep the phone in AC same effect, that is worst as can't blame outside temperature.
Also i am using wifi. Bluetooth and location are turned off. Phone is optimised used device care and all other apps are closed
Is there any solution or update planning to rollout ?
Please don't reply with typical answers Iike reset device, turn off wifi, blutooth. It's a serious software issue and Samsung needs to address this as soon as possible.
Giving this kind of crappy update is so irritating for the users.
31 Comments
MGowtham
I am facing same issue.. I thought it's only for me.
ozoi
Beginner Level 4
Me too, I hust got this phone a week ago. And as soon as I started using and setting up my new phone, it heated up uncomfortably. That is not supposed to happen when the phone is just out of the box.
goodthings
goodthings
Your's most welcome to here.
HARIRAJ1809
Same bro but not at a high range
jwalker
It's 39 ° C after 5 mins of usage. Sometimes its 36 to 37, both are not expected with light usage. Also i amusing in a cool environment.
Hemanth4446
What is the sot and stand by time are you getting? And what is the temperature it's reaching?
jwalker
Most of time it is 39 °C .
Sometimes 42.
Sot is 5hr with normal usage
Hemanth4446
I'm also using S23 I'm getting 7hrs of sot and 1day of stand by time.. And my device ideal temperature is between 32 to 36 degrees while using what's app, Instagram and YouTube
