Samsung Notes High battery drain and Background usage
(Topic created on: 04-23-2023 03:56 AM)
agentvj
I have S23ultra and Tab s8. In both devices Samsung Notes uses around 10% per hour. It has high background usage of 5-7 hours. How to limit this. Have anyone solved these issues
9 Comments
S_Kumar73
Turn of sync with Samsung cloud and one drive. Screenshot_20230423_042250_Samsung Notes.jpg
agentvj
Thank you, will the sync run even if the Wi-Fi is off.?
S_Kumar73
It's a program, it always trying to connect network. Once the network is available it starts syncing. Try to turn off and then check
Not applicable
When any of my apps run in the background for long hours, I receive notifications & it says to put the app into deep sleep. I do as it says & the app stops running in the background.
agentvj
But for Samsung notes there is no option to put it in sleep
Not applicable
But it has on my phone. Go to settings -> battery & device care -> battery -> background usage limits -> deep sleeping apps -> add samsung notes on the list.
S_Kumar73
U can
agentvj
Please help me to make it sleep
S_Kumar73
See the screenshot. Just clock add sleeping apps. From there u can add apps that u want to make it sleep1682238857479_1682238857469_0.jpg
