Devv_007
08-13-2023 03:32 PM (Last edited 08-13-2023 03:33 PM ) in
Samsung flow stuck in this page and isn't connecting to PC, any solution?
Tried clearing its data but still not connecting.
Solved! Go to Solution.
john163
08-13-2023 04:06 PM in
try to remove device added and re add..,this app is buggy aswell..have to re add device again to connect sometimes
3 Comments
john163
Devv_007
08-13-2023 04:20 PM in
Thanks for the reply,got it worked by adding the device in pc.
goodthings
08-13-2023 04:47 PM in
My dear added device remove and re add again same device after some time. Thanks.
