[SOLVED] Galaxy S8 - Bootloop problem
(Topic created on: 08-11-2021 04:23 PM)
Not applicable
Hello, my friend has a big problem. He has S8, 3 years old. He charged phone overnight, and in the morning, the phone were turned off, itself. Tried to turn on, but it's stuck on Galaxy S8 logo, 10 hours turned on and bootlooping, even S8 Powered By Android logo won't remove, screen burn-in! Resetted 5 times, nothing. Changed everything, display, back glass (from black to blue, the glass broken while opening phone and it's not solved.
Even charging screen won't show! It bootloops...
Edit: S8 is now fixed, it were a software problem.
121 Comments
Not applicable
Flash with Odin...
Not applicable
But Phone is damaged, so how do you flash it. What if it crashes?
Not applicable
S8 is already crashed😂
Not applicable
I already said Phone is damaged, then how will you flash it?
Even phone is fully bricked
Flashing with odin brings phone(galaxy) back to life
I also flashed j5 with odin after brick
Not applicable
You came after 19 hours. 😑😑😑
Woops
Not applicable
How many meetings you have in a day?
Not applicable
Yes, but flashing is only for bricking (like your J5), bootlooping (like S8), not getting OTA updates or firmware is messed up.
Yes !
Is Now s8 fixed ?
