S9 plus Extremely Battery Drain issue after Software update
(Topic created on: 02-06-2022 04:33 PM)
sklabib
After last samsung Softwer update of Nov, 2021.
Suddenly my S9 plus battery start draining when It's reach 30% and it takes 5 minutes to reach 30% to 0%.
Any solution please
10 Comments
TjSi
Your battery health might be less than 70% so better to get it serviced. Also ask them to do a fresh firmware reset so backup your data
sklabib
Thanks for your information..
I understand but my phone battery was fully okay the day before update.
After update suddenly this problem is happening. Does samsung battery health could reduce suddenly in one day😐?
By the way i get good performance when the battery charge stay in 100% to 31%
TjSi
Battery is already degraded. The phone is 4 years old. The new software just doesn't show the true battery level anymore. If you still don't feel right you can always do a fresh firmware flash through Odin but yes you still need a new battery pack
sklabib
okay and thanks again❤️
WalkieTechie
Expert Level 4
Before going for battery replacement or anything. Just reset the phone from recovery mode (it will remove all data so better take a backup beforehand).
sklabib
Thanks. I will do that.
WalkieTechie
Expert Level 4
Have you done it?? If not then 1st reset all Settings and see for 1-2 days. If it doesn't work then go for full reset as I mentioned before.
izharraja
Latest update information
Android 11
izharraja
Really Battery change only 6 month but after updating of Nov, 2021 battery auto drain really. Please request new updates and any solutions
