S9+ Plus Color Banding issue and Crusing black color andd gradients
(Topic created on: 07-14-2019 09:59 PM)
hardikforall
Recently i have noticed that.
in dark rooms the gradients are not smooth and there is issue with black color range.
it is very bad while watching darker scenes and at that time the colors are distorted and not proper. i felt this issue recently after changing wallpaper from themes.
is this software level or hardware level issue. i can see the screenshot sent to other phone looks the same so its may be software issue.
i have also tried cache and data partition wipe/factory reset. but same thing.
10 Comments
Subhajeet_Das
i think it's a hardware issue.Do you have ever changed your display or is your display cracked?please reply
hardikforall
No i havent changed display and there is no any crack. it looks perfectly fine on higher brightness. its just when i am in dark room or in night when brightness is at low. i checked few forums and they
suggested it happens with some samsung mobile display
Also i am not able to see/identify the first top row black strip in the mobile display. but look fine in other devices.
Black crush testBlack crush test
Subhajeet_Das
Then i think the display connector cable got damaged some how that's why in low brightness the colour banding problem happens.If you have warranty still then please go to official samsung service centre. Don't repair your phone from somewhere else because they can also damage your working good display. Thank you.
hardikforall
The issue seems quite widespread and I hope Samsung comes with an official response on this soon.
https://us.community.samsung.com/t5/Galaxy-S9/Black-Crush-and-Gradient-Banding-Issues/td-p/294889
there is long thread on Android central
https://forums.androidcentral.com/samsung-galaxy-s9-s9-plus/875471-galaxy-s9-plus-black-crush-gradie...
1907kar
Me too facing the Same issue.. do u have any resolution...
ur2kill
this is a software issue i guess, and is also present in my week old galaxy Note 10+, please like and comment on my post👇
https://r2.community.samsung.com/t5/Galaxy-Note/Video-Playback-Colour-Gradient-Banding-amp-Black-Cru...
Abusaleh77
bro your display is solved by the next update???
ur2kill
no not even on current latest software, its an issue present onpy in Exynos variants, idk why but most probably due to faulty video decoder software
cs-member13
Expert Level 4
Dear Samsung Member,
We would request you to kindly send us the screenshot, video and error log file with in 15 minutes of issue occurrence through error report section from Samsung Member Application:-
Samsung member application > Click on get help > Send feedback > Error report, so that we can help you out with this.
