S9: Overheating, lagging & poor battery performance.
(Topic created on: 04-13-2020 07:15 PM)
ram_lodha09
After March security patch updates my s9 is getting overheated in normal usage & lagging in performance. Even Battery performance is dropped drastically...
Is anyone also facing same issues???
Solutions for this🙏🙏🙏
17 Comments
Pritpal2191
im eperiencing same problem
immi007
every user has this same story.... same here.
backup and reset helps somewhat..
ram_lodha09
reset method is not that much working...
immi007
sorry bro . i can't suggest anything other than that. you can optimize your phone by adjusting some setting that's it.
ankitgawande
Actually the was not updated in proper way or may be there was some network fluctuations... so you have Software update it again with proper OS at service center.
ram_lodha09
its not from our end i think... this are all bugs from Samsung for slowing the devices...
jainpritam451
Decrease 3rd party apps.and visit samsung care once!
ram_lodha09
default apps & some other apps for office work nothing extra in the device... from last few days device is burning like a oven😅
ankitgawande
Still I would like to suggest visit service center when its possible
