S8 Plus Wifi Problem
(Topic created on: 08-13-2018 11:44 PM)
BT71
Dear All,
Whenever I connect my s8 plus to WiFi network. after sometime it gets disconnected automatically with error symbol '!'.
I states internet may not be available.
I am sure that my internet connectivity is very good as my iPhone is connecting on the same network perfectly.
Please provide suggestions.
Refer attachments.
17 Comments
sen001
Try after you switch off ur Bluetooth. Some times it interferes.
BT71
ok. let me try this.
PranShank
Is it the first time your device is connecting to this network?
BT71
no. First it was working fine. From last one month facing problem.
PranShank
Try to forget that network and join again.
A7 2017 mein bhi same ho raha hai
Gokul17
it happens in some Samsung phones....in my j7 pro also sometimes suddenly wifi disconnects and does not connect again and have 2 wait a min 2 connect again....and also u stated problem also exists..what 2 do just got used to it....
VasuGalaxyF23
it's not your device fault it's your WiFi networks fault... S8 shows the icon and iPhone dosent ... you will see that the time it happens your iPhone will also not work... I do have both phones and I am sure of it.... 100%... Don't worry
BT71
I'm not facing any issue in my iPhone and other Samsung devices as well.
Thanks for your comment.
