S7 Edge Fingerprint sensor
(Topic created on: 11-25-2017 03:49 PM)
Aadi
After the recent update on my s7 edge i am unable to use fingerprint sensor in MAX POWER SAVING MODE to unlock my device. Has this feature been removed?
4 Comments
Devv_007
ya they removed it. I think they have done it to save maximum battery of device.
shohbi
bhai is me biometrics options stop ho jata for save more battery
Diabolical
they shouldn't have removed it...it doesn't consume too much battery -_-
admin_
Thanks for being with Samsung and sharing your concern. We would like to inform you that on the max power saving fingerprint sensor will not work in order to save the more battery so please use mid to use fingerprint sensor. Be sure to hit ♡ when you find an answer that works for you.
