[S25Ultra] Battery Drain due to GoodLock
(Topic created on: yesterday)
iAshyUS
Device: Galaxy S25 Ultra
Build: AYDA (May 2025)
I am using these modules (ref. screenshot) on GoodLock and experiencing significant battery drain.
When turned OFF or uninstalled, the battery drain gets much better on same device settings.
I just don't get why Battery Settings do not show GoodLock or any installed modules in battery consumption stats.
Any clue? Anyone?
WalkieTechie
Expert Level 4
The battery drain is not due to Goodlock majorly. Mnay users are experiencing battery drain after the latest One UI and the latest security patch update. It will most likely be fixed in the next security update.
