S25 Ultra Battery Drains So Quickly
(Topic created on: 03-01-2025 08:15 PM)
MuHaMMaDKaSHiF
2Hrs Sot only @54% Battery...
With no gaming no camera only browsing and few app usage..
Already putted apps on deep sleeping
And sleeping apps
Adaptive Battery saving was on
Using performance on light mode
Display on FHD
9 Comments
syedamaan09
My 24-ultra gives around 9 hours of SOT.
Ultra_Devil
Same my gave me 10-11 hrs of 100 % and 8 - 9 on 80 %
Follow this to resolve ur problem.
https://r2.community.samsung.com/t5/Galaxy-S/To-Increase-Battery-Life-on-S24-S23-Ultra/td-p/15509875...
24 hours and 54% used, how's it bad sir? Please help me understand.
If you take 3 days to get 10 hours sot, your phone should stay on?
Bad in terms of SOT ..standby time is only 1 day and 8 to 9 hrs..
And the settings what i use to get more battery i have already given brother..
My point is having all these in phone as a benefit of premium or powerful phone..
I am using light performance mode which reduces the performance of 8 elite to get more battery.
Fhd display
Location off
Auto sync off
Putted apps to Deep sleeping mode
Ohh okay. I'm at 66% used for 6h sot so far. I've done gaming a lot yesterday, more than 3 hrs, rest of it is generic.
You are getting a Perfect SOT time..
Mine is with gaming i believe it will last 4 hrs only with BGMI
See its same even my phone SOT time is less it should get more standby time..1740893121495.jpg
cs_member8
Dear Samsung Member,
As per your concern, we want to inform you that when initially using the device, battery consumption may be rapid due to learning battery usage patterns and application of performance optimization. It will stabilize after a certain period, but if still facing issues, kindly perform the following steps to resolve your issue.
● Galaxy device Battery drain issue: Note: Charge in one go instead of charging many times as it affects the life span of battery and battery performance.
9. Update software (if available): Go to Settings > Software update > Download and install > Check for software update > If Software update available > Download > Downloading updates > Install now
10. Reset the device:
IMPORTANT:
• For this:
• Open Gmail (https://accounts.google.com/servicelogin) > forgot password >Select """"try another way"""" > Next > Enter a new password > Next
If the issue still persists than we request that you share the log file from your device within 15 minutes of the occurrence of the issue. You can do this by using the error report option available in the Samsung Members application.
Additionally, if possible, please include a video or screenshot demonstrating the issue. Here are the steps to share the log file:
To share a log file, (Open Samsung member application >> Tap on support >> Tap on send feedback >> Choose composer option >> Select error >> Select the appropriate category >> Type your query)
aryan2306
I think I may found the problem it is also happening for me after feb update
Disable samsung weather app
It is constantly running after feb update no way to restrict the option is blurred
