S24 plus battery life 70 % on 5g 30% on wifi
(Topic created on: 05-08-2024 10:16 PM)
lakshyagrover1997
Battery includes mild gaming aod gps on dual sim too
10 Comments
rahulopg
Its good
Yeah good as also had 15 min bgmi gaming session though on 5g only
rahulopg
Hmm..you use instagram a lot as i can see. Or else you should hsve got around 7 hrs of sot with s24+ ino.
Yeah on daily use it gets 7 hrs 8 plus if on dark mode nice looks like in real life 2400 has better battery than 8gen3 as it heats less as compared to 8gen3
rahulopg
Ok
Gen 3 is just bit better reincarnation of 8gen1 great peak performance but drops to 778g level under pronlonged session 15 to 20 min of intense workloads
rahulopg
May be thats done purposely to manage the heat. But imfo I have not faced any performance drop in my s24U during peak use also
Do you play genshin at full blast then its problem for most pepole like no problem beacuse we don push our devices 24 × 7
rahulopg
No i dont play genshin impact but ya I have played long sessions of COD mobile during which though it gets hot but performance has never dropped
