S24+ call quality issue
(Topic created on: 01-25-2025 09:03 AM)
SureshSaravana
Hi all! 👋 I recently bought the S24+ and I'm facing call quality issues. Anyone else having the same problem or have any suggestions? 🤔 Please let me know! 🙏 #Samsung #S24Plus #CallQuality #Android #PhoneProblems
8 Comments
rayeesah
Many users are facing the same problem due to exynos chip set.
Is there any way samsung will fix through OS update?
rayeesah
Maybe it is possible, also try restarting your phone and reset Mobile network settings and check sim card is inserted properly.
Sure, let me do this 🙏 thanks for the info
Kaushik566
S24 plus does support Navic and dual frequency GPS?
goodthings
goodthings
Your's most welcome to here.
cs_member8
Dear Samsung Member,
As per your concern, we would request you to kindly visit this mentioned link to resolve your issue by using the below-given link.
● Galaxy device network issue: https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-smartphone-how-to-optimise-network-...
In case the issue still occurs, kindly visit the service centre for a physical inspection of your device. You can locate your nearest service center with this given link: https://www.samsung.com/in/support/service-center/
