S24 Ultra Problem - 50 and 200MP
(Topic created on: 10-25-2024 05:15 PM)
surya7670
There
is a serious issue in S24 Ultra cameras with 50 and 200 MP mode.Images Taken from these modes are getting washed out/blurry always which makes these sensors useless 😭😭Spending a lakh rupees for a flagship phone and getting this kind of result is even worse !
cs_member8
Dear Samsung Member,
As per your concern, we want to inform you that Samsung has found an issue where camera images may be affected at specific zoom levels when using the 'Maximum' option in Intelligent Optimization.
A software patch is being developed to address this issue, so it's important to keep your device's software updated. As a temporary solution, you can adjust the quality optimization setting to 'Medium' or 'Minimum' within the Intelligent Optimization section of the Camera settings.
Path: Camera app > Settings > Intelligent Optimization > Quality Optimization and select either 'Medium' or 'Minimum'. The default setting is 'Maximum'.
Kindly check first if there are any broken camera lenses or scratches on the camera, no laminated or tempered glass is pasted on the camera if not then check after the camera lens cleaning.
Use a microfiber cloth or a cleaning wipe. Gently remove the fingerprints, dirt, and dust from the camera lens.
Reset the camera settings: Home screen tap on Camera>Settings>Reset settings>Reset.
Clear camera application data: Apps>Camera>Storage>Clear Data
Check app cache: Settings > Apps > Camera> Storage > Clear Cache.
You can reset your device by following the steps.
If the issue persists, kindly report the problems with a log file. To share a log file, click on the Samsung Members Application (Open the Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select Error report > select the appropriate issue category> Type your query and send).
