FernasHasan
04-04-2024 11:57 AM in
Hi
an example of this post processing disaster 🤦
I've been trying to take photos at low light, and each and every time the post-processing of the photo just completely ruins the photos. I tried each and every trick I know to stop this processing with no success. below are 2 examples.
any advice?
again .. look at the blue light
4 Comments
Zammi
04-04-2024 12:14 PM in
Have you tried intelligent optimization: Minimum option?
FernasHasan
04-04-2024 12:15 PM in
yes I have .. same results
FernasHasan
04-04-2024 12:26 PM in
interesting .. I looked at a previous post of yours .. it seems you have a kind of same issue with your camera (the blue over saturation, and spread out) .. I'm not sure if that's a software issue that only Samsung can fix
Zammi
04-04-2024 12:30 PM in
Yes it's software. Try Expert Raw, raw format. It's completely different. This is a post-processing issue.
